12 years ago
Multiple Constant Driver Error
My VHDL is a little rusty and I'm trying to get back up to speed but I've run into a problem with the code below and can't determine the source of the problem. In short, I've generated an array of registers and have reset it in two parts, registers 6 - 0 in one process and register 7 in another. This seems to not have a problem until i introduce the statement in line 51 (the bold text). The statement is to equate DATA_OUT to Fifo(0) but when not commented out causes errors: "Can't resolve multiple constant drivers for net "fifo[7][0]" I receive errors for all 9 bits in fifo[7] register. I can't see how equating the output of this register to the DATA_OUT causes multople drives in another register. Help?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
Entity FIFO is port(
DATA_IN: in STD_LOGIC_VECTOR(8 downto 0);
DATA_OUT: out STD_LOGIC_VECTOR(8 downto 0);
WORD_RDY: out STD_LOGIC;
FIFO_FULL: out STD_LOGIC;
WORD_RD: in STD_LOGIC;
WORD_WR: in STD_LOGIC;
RESET_N: in STD_LOGIC;
SYS_CLK: in STD_LOGIC);
end FIFO;
Architecture FIFOXN of FIFO is
-- constant Depth: Integer:=8;
type Register_Array is array(7 downto 0) of STD_LOGIC_VECTOR(8 downto 0);
signal Fifo: Register_Array;
signal Shift: STD_LOGIC;
signal Lead_Data: STD_LOGIC_VECTOR(2 downto 0);
signal Tail_Data: STD_LOGIC_VECTOR(2 downto 0);
signal New_Word: STD_LOGIC_VECTOR(2 downto 0);
signal Wd_Latch: STD_LOGIC;
Begin
-- This section defines the registers and data motion withing the
-- register set. There are two pointers, Lead_Data md Tail_Data that
-- track the data in the registers; Lead_Data moves the data to the
-- output of the Fifo and Tail_Data moves the input data to the last
-- unfilled location.
data_out <= fifo(0); -- this statement causes problems.
process(SYS_CLK, Fifo, Tail_Data, Lead_Data,RESET_N)
variable pointer: Integer := 0;
-- Note: this section runs form the same clock that is used for the X4CLOCK in the send and receive
-- sections of the UART. That way there is no more than one word at an unknown location in the FIfo
-- at a time.
begin
if RESET_N ='0' then
for i in 6 downto 0 loop
Fifo(i) <= "000000000";
end loop;
Lead_Data <= "111";
Tail_Data <= "111";
New_Word <= "111";
elsif (SYS_CLK'event and SYS_CLK ='1') then
-- Lead_Data Control Logic. This waits for the first word
-- then shifts the word to the beginning of the register set
-- If the last word count is "000" then the Lead_Data resets to
-- "111" indicating the Fifo is empty.
if (Lead_Data = "111") then
if Wd_Latch ='1' then
Lead_Data <=Lead_Data -1;
end if;
elsif (Lead_Data =not("000")) then
elsif (Tail_Data ="000" and WORD_RD ='1')then
Lead_Data <= "111";
end if;
-- This controls the Tail_Data control logic. When Lead_Data is not "111" and
-- a new word is received then the Tail_Data counter shifts the new input word to
-- end count +N where N is the nunber of words in the stack. N is decrumented by
-- reading the head word in another section.
if (Lead_Data = not("000")) then
Tail_Data <=Lead_Data;
elsif (Wd_Latch ='1' and WORD_RD ='0') then
Tail_data <= Tail_Data +1;
elsif (Wd_Latch ='1' and WORD_RD ='1') then
Tail_data <= Tail_Data;
elsif (Wd_Latch ='0' and WORD_RD ='0') then
Tail_data <= Tail_Data -1;
end if;
-- This logic controls the New_Word counter. This counter tracks the new word through the
-- the fifo as is is shifted to the new tail location. The Tail_Count is incrumented when
-- the new word reached the back of the line.
if New_Word ="111" then
New_Word <= New_word -1;
pointer := pointer -1;
end if;
elsif New_Word =not("111") then
if New_Word = Tail_Data then
New_Word <= New_word - 1;
else
New_Word <= "111";
pointer := 7;
end if;
end if;
-- This section controls the register latching operations based on the conditions of Lead_Word,
-- Tail_Word, and New_Word.
if Lead_Data =not("111") then
for i in 7 downto 1 loop
fifo(i-1) <= fifo(i);
end loop;
elsif New_Word = not("111") then
fifo(pointer - 1) <= fifo(pointer);
end if;
end if;
end process;
-- This process controls the data entry to the lead register in the fifo array. The WORD_IN
-- consists of 8 bits of data, an error bit from the receiver.
process (SYS_CLK,WORD_WR, RESET_N)
begin
Fifo(7) <="000000000";
if WORD_WR ='1' then
Fifo(7) <= DATA_IN;
Wd_Latch <='1';
else
Fifo(7) <= Fifo(7);
Wd_Latch <='0';
end if;
end if;
end process;
--This is the garbage process for misc signals.
begin
FIFO_FULL <='0';
WORD_RDY <='0';
if Lead_Data <=X"0" then
WORD_RDY <='1';
else
WORD_RDY <='0';
end if;
if TAIL_DATA = "111" then
FIFO_FULL <='1';
else
FIFO_FULL <='0';
end if;
end if;
end process;
end FIFOXN;
    The problem is rather caused by the below assignment which needs a constraint (e.g. if pointer <=7)
    Thanks. I replaced the statement with a case statement and that seemed to work. I then had second thoughts and rewrote the code to eliminate the variable use. Thanks for your help.
