13 years agoi think i found the problem.
i watched with the rtl viewer and i see that the registers inside the FSM have not the enable driven by my clk_en but from the reset! So my multicycle constraint isn't applied to the majority of nets. I usually write processes like: process(clk_i) begin if rising_edge(clk_i) then if reset = '1' then register <= '0'; elsif clk_en = '1' then if condition_1 = '1' then ---operations end if; end if; end if; end process; i think this way should be used with xilinx flip flop, not for altera. How do i code it correctly?
