10 years agoMulti-processor aoc compilation
I am currently compiling a rather hardware-intensive kernel. The compilation time just got over 24 hours and it is still running.
I know Quartus can use multiple processors when compiling, but when I look at the Windows task manager, I only see one processor with one core active. Can I use multi-processor compilation only from Quartus' gui or is there a way to let it use multiple cores? (I have Quartus set to use all available processors.) I have read something about this here:http://www.alteraforum.com/forum/showthread.php?t=478&highlight=multithread, but that did not help.3 Replies
I just saw Quartus map using 2 threads (for one minute it were even 5), so it seems to be working fine. I did not change my settings, only compiling a different kernel.
Some extra info: I just looked at the Quartus project settings, there the limit was set to 4 processors, but I have seen it use more than 4. So it looks like the command line Quartus does not use this.
hi,
you can try to open file: quartus_sh_compile.log or top.sta.rpt and search "processor" or "Processor". you will get something like this:- +------------------------------------------+
- ; Parallel Compilation ;
- ; Processors ; Number ;
- ; Number detected on machine ; 8 ;
- ; Maximum allowed ; 5 ;
- ; Average used ; 1.12 ;
- ; Maximum used ; 5 ;
- ; Usage by Processor ; % Time Used ;
- ; Processor 1 ; 100.0% ;
- ; Processors 2-4 ; 3.5% ;
- ; Processor 5 ; 1.4% ;
