16 years agoYeh, what strange is with Xilinx ISE it automaticallt takes it's generated memory block similar to what MegaWiz creates and puts that entire memory instance as a single block, then when you go to view it in waveforms, you see location zero up to the end in 8 bit values which you can assign as say a Hex value so it is very easy and quick to see the memory contents.
thx
