GLT1
4 years agoMPFE for Stratix 10 EMIF?
For past designs, I've used the UniPHY SDRAM memory controller for a DDR memory interface. That controller contained a multi-port front end (MPFE) which could be used to create multiple s...
- 4 years ago
OK, thanks. I don't think SGDMA is going to work for our application, since we have multiple masters who need to access the memory.
Intel should consider bringing back the MPFE for the newer EMIF IP core. That was a really useful feature. To get rid of that without an equivalent replacement makes porting older designs to newer device architectures extra difficult.
Terry
GLT1
4 years agoHi Adzim,
That might work, but the port out of the EMIF core is Avalon-MM rather than Avalon-ST.
Are there components to convert MM to ST and then from ST back to MM? I can't seem to find anything like that in the Platform Designer IP list.
Thank you,
Terry
