8 years agoMonte Carlo Black-Scholes Asian Options Pricing Design Example
After several false starts, I have a working OpenCL environment with immense help from Nallatech. Since the type of problems I want to solve is similar to Intel's Monte Carlo BS pricing example, I w...
8 years agoRather than removing the unrolls, it is probably best just to decrease the unroll factors up to a point where the predicted DSP utilization by the compiler goes below 100%. When you overutilize the DSPs, the mapper will try to map the extra functions to logic, which will significantly increase the logic usage and complicate placement and routing and result in much longer placement and routing time.
