mappy5
4 years agoModule removal by compilation optimization
I want to synthesize soft CPU IP by itself and evaluate resources.
I created a TOP wrapper to implement a CPU module. However, when I look at the compilation result, I can't find the CPU module I ...
mappy5
4 years agoCPU was released by the 3rd vendor.
I created a Top wrapper that outputs the IO of the CPU Top module to the FPGA pin.
However, since the number of CPU IOs is large for FPGA pins, some inputs are input from registers.
- sstrell4 years ago
So can you answer the question I asked? What exactly does the report indicate is getting optimized away? And have you tried adding virtual pin assignments?
