9 years agoModified default value of generic parameter does not trigger correct make on Q17 ?
Hello, The following module intializes the parameter of ent_bug 'v' with value 1 and the second one instantiates the first module and sends the output to a 7SEG display of a DE0: library i...
9 years ago --- Quote Start --- The value of generic is meant to be passed when you instantiate the design: ENTB: entity work.ent_bug(arch_bug) generc map( ...) port map(result=>bugVal ); --- Quote End --- yes and no. If a generic isnt assigned, it is supposed to take the default. I suspect this is a quartus bug not checking for changes in defaults when it recompiles code. I seem to remember someone else posting this same problem. I would raise a ticket with altera over this.
