NH_Dal
5 years agoModelSim Wave Image Export Error - image file format "bmp" is unknown
I am using Quartus Prime Lite 20.1.1 with ModelSim Intel Starter Edition 2020.1 Revision 2020.02.
No matter what image format I select, if I try to export an image from Wave, I get the error:
i...
RichardT_altera
5 years agoThis is a valid bug in Window OS and engineering will fix this in the future release.
As of now, the current workaround is to run the Modelsim/Questa Intel Edition simulator in Linux OS or you may use third party vendor tool to export the wave image.
If these is no further help needed, I will proceed to close this case.
Richard Tan
