NH_Dal
5 years agoModelSim Wave Image Export Error - image file format "bmp" is unknown
I am using Quartus Prime Lite 20.1.1 with ModelSim Intel Starter Edition 2020.1 Revision 2020.02.
No matter what image format I select, if I try to export an image from Wave, I get the error:
i...
RichardT_altera
5 years agoThat's weird...I also get the same thing.
Let's me check with the engineering team on this.
For now, please use snipping tool or screenshot as a workaround.
- Pietro45 years ago
Me and my mates have the same problem, I can't even print a readable file.
The only way is to print a pdf file but that's not what I need.
- RichardT_altera5 years ago
Hi Pietro4,
May I know what do you meant by "I can't even print a readable file."? Is the issue related to Modelsim? Could you help to describe more on this? Appreciate if you could share the screenshot.
Richard
