amildm
Contributor
4 years ago[ModelSim] vsim command - why Wave window is reloaded?
I'm about the vsim command...
Here is how I'm used from the Transcript window:
%> vsim -t 1ns \ -L work \ -L work_lib \ -L altera_ver \ -L lpm_ver \ -L sgate_ver \ -L altera_mf_ver \ ...
- 4 years ago
The 'restart' command should solve the problem for restarting the simulation after recompilation the whole design...
It seems that the 'restart' command is a subset of the vsim command...
SyafieqS
4 years agoThe relation is for typical design that has not changed and you just want to run it against an updated testbench. In this case you can restart simulation by executing a custom script that you call with the 'do {script-name}' command whenever needed.
