amildm
Contributor
4 years ago[ModelSim] vsim command - why Wave window is reloaded?
I'm about the vsim command...
Here is how I'm used from the Transcript window:
%> vsim -t 1ns \ -L work \ -L work_lib \ -L altera_ver \ -L lpm_ver \ -L sgate_ver \ -L altera_mf_ver \ ...
- 4 years ago
The 'restart' command should solve the problem for restarting the simulation after recompilation the whole design...
It seems that the 'restart' command is a subset of the vsim command...
amildm
Contributor
4 years agoSo, when the elaboration phase is done? If it's not an independent stage, is it done during the code compilation (vlog) or simulation (vsim)?
Will the 'restart' command re-run the simulation on the latest compiled code automatically?
you wrote: "Restart button should be rerun you compilation and simulation (whatever command in your .do file )" - what's the relation between the RESTART button to my *.do file???
Could the RESTART button be customized?
