amildm
Contributor
4 years ago[ModelSim] vsim command - why Wave window is reloaded?
I'm about the vsim command...
Here is how I'm used from the Transcript window:
%> vsim -t 1ns \ -L work \ -L work_lib \ -L altera_ver \ -L lpm_ver \ -L sgate_ver \ -L altera_mf_ver \ ...
- 4 years ago
The 'restart' command should solve the problem for restarting the simulation after recompilation the whole design...
It seems that the 'restart' command is a subset of the vsim command...
SyafieqS
4 years agoMay I know if there is any other concern on this?
Restart button should be rerun you compilation and simulation (whatever command in your .do file ), its not an elaboration.
