amildm
Contributor
4 years ago[ModelSim] vsim command - why Wave window is reloaded?
I'm about the vsim command...
Here is how I'm used from the Transcript window:
%> vsim -t 1ns \ -L work \ -L work_lib \ -L altera_ver \ -L lpm_ver \ -L sgate_ver \ -L altera_mf_ver \ ...
- 4 years ago
The 'restart' command should solve the problem for restarting the simulation after recompilation the whole design...
It seems that the 'restart' command is a subset of the vsim command...
sstrell
4 years agoI think you're confusing compilation in Quartus vs. compilation in a simulation tool.
Elaboration is part of building the design hierarchy in Quartus. The commands you mention do something similar in the simulation tool. You still have to always add the signals to the Wave window after you compile the design in ModelSim or QuestaSim.
amildm
Contributor
4 years agoThe 'restart' command should solve the problem for restarting the simulation after recompilation the whole design...
