[ModelSim] vsim command - why Wave window is reloaded?
- 4 years ago
The 'restart' command should solve the problem for restarting the simulation after recompilation the whole design...
It seems that the 'restart' command is a subset of the vsim command...
Hi Dmitry,
Does previous reply helps?
Yes, You should select the signal and add wave to the window to see it.
- amildm4 years ago
Contributor
Is there a way to compile/simulate design in 3 following steps?
1) compilation
2) elaboration
3) simulation
As for compilation, the vcom/vlog commands are used, for simulation - vsim...
What command is used for the design elaboration?
- sstrell4 years ago
I think you're confusing compilation in Quartus vs. compilation in a simulation tool.
Elaboration is part of building the design hierarchy in Quartus. The commands you mention do something similar in the simulation tool. You still have to always add the signals to the Wave window after you compile the design in ModelSim or QuestaSim.
- amildm4 years ago
Contributor
