9 years agoModelsim: Unresolved defparam reference to somewhere
In Quartus ii schematic diagram, i've generated an lpm_ff. Then i've converted the design to a .v file. when i want to use this flip-flop in a module, it compiles with no problems but when i want to simulate it with modelsim i receive this error for all defparams in the code in the :
Error: (vsim-10000) C:/.../lpm_ff_8.v(30): Unresolved defparam reference to 'LPM_WIDTH' in lpm_instance.LPM_WIDTH. Here is the code of `ff` that Quartus generated: module lpm_ff_8(clock,sload,data,q);
input clock;
input sload;
input data;
output q;
lpm_ff lpm_instance(.clock(clock),.sload(sload),.data(data),.q(q));
defparam lpm_instance.LPM_AVALUE = 1;
defparam lpm_instance.LPM_FFTYPE = "DFF";
defparam lpm_instance.LPM_SVALUE = 0;
defparam lpmi_nstance.LPM_WIDTH = 16;
endmodule
And the module i use this flip-flop in it:
module test(input a, clk, output reg q);
lpm_ff_8 regg(.data(a), .clock(clk), .q(q));
endmodule
module testTB();
reg a;
reg clk;
wire q;
test t(a, clk, q);
initial begin
# 15 clk = 1;
end
endmodule
I also add lpm_ver library when i want to simulate. So can you help me to find what's wrong with this code?1 Reply
1. Here is Typo mistake, Defparam lpmi_nstance.LPM_WIDTH = 16; ---> lpm_instance.LPM_WIDTH 2. Missed port sload while instantiation & declare all inputs & outputs before use it & then instantiate, lpm_ff_8 regg(.data(a), .clock(clk), .q(q)); note: unfortunately handled old thread while handling thread 59117 Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
