16 years agoModelsim: top module not testbench
Hi. I was trying to run the simulation using native link method. When the modelsim in simulation mode, the top module always is the design module instead of testbench. in the .do file, v...
14 years agoHi,
Please see my last post. If you are running the simulation using Native Link (launching via the tools-> Run Simualtion Tool. The options passed to the generated scripts come from the Assignments->Settings->Simulation menu. Please ensure your have followed the flow: 1. Select "Compile a testbench" 2. Press the "test benches" button 3. create new 4. correctly specified the details (module names) 5. Add your testbench files in the Test bench files section.
