16 years agoModelsim: top module not testbench
Hi. I was trying to run the simulation using native link method. When the modelsim in simulation mode, the top module always is the design module instead of testbench. in the .do file, v...
16 years agoHi, the top level module, or rather the testbench must be set in the settings->EDA tool options->Simulation->Native Link Settings-> testbenches-> new / edit
The top level name used in the .do is taken from the settings for the Testbench, Name (just a name), Top level module in test bench (entity name of testbench), Design instance (instance name of UUT).
