Modelsim starting vsim with out typing the additional -L <library> each time
I see other projects which start vsim without specifying the additional libraries it uses.
On my simulation projects, I have to use the -L option to start vsim otherwise modelsim will complain module 'X' is not defined.
For example, I manually compile quratus primitives quratus_mf.v from the eda library and name it altera_mf_ver.
To start simulation with vsim I have to use vsim -L altera_mf_ver work.top otherwise model sim will error out with. For example, the issue I have is that I need PLL megafunction but alt_pll not defined unless I include altera_mf_ver.
I check to see my library is in the [Library] section to my project setting file *.mpf which thought would help but for my project
I still have to add -L altera_mf_ver option in the vsim command each time. How does everyone else do it?
- Abe
Are you using the Intel FPGA Edition of ModelSim or a standalone edition? If using the Intel FPGA edition, the device libraries should already be precompiled for the simulator and you can see them in the libraries list.
If using a standalone version, you will need to compile the device libraries for the simulator via Quartus -> Tools- > FPGA Library compiler. Select the simulator , specify the path to the simulator and then choose the device family and compile. This will create the device specific libraries for ModelSim.
To simulate the designs, you will need to specify the libraries using the -L option. The other way around is to compile the required device libraries into your designs work folder and then simulate. This way the libraries and components are all available in the Work library and you need not specify the -L option.
Another option is to specify the libraries in the Modelsim.ini file that resides in your work library. Edit the file and add the following lines to it:
; Altera Primitive libraries
; VHDL Section
altera_mf = $MODEL_TECH/../altera/vhdl/altera_mf
altera = $MODEL_TECH/../altera/vhdl/altera
altera_lnsim = $MODEL_TECH/../altera/vhdl/altera_lnsim
lpm = $MODEL_TECH/../altera/vhdl/220model
220model = $MODEL_TECH/../altera/vhdl/220model
maxii = $MODEL_TECH/../altera/vhdl/maxii
maxv = $MODEL_TECH/../altera/vhdl/maxv
fiftyfivenm = $MODEL_TECH/../altera/vhdl/fiftyfivenm
sgate = $MODEL_TECH/../altera/vhdl/sgate
arriaii = $MODEL_TECH/../altera/vhdl/arriaii
arriaii_hssi = $MODEL_TECH/../altera/vhdl/arriaii_hssi
arriaii_pcie_hip = $MODEL_TECH/../altera/vhdl/arriaii_pcie_hip
arriaiigz = $MODEL_TECH/../altera/vhdl/arriaiigz
arriaiigz_hssi = $MODEL_TECH/../altera/vhdl/arriaiigz_hssi
arriaiigz_pcie_hip = $MODEL_TECH/../altera/vhdl/arriaiigz_pcie_hip
stratixiv = $MODEL_TECH/../altera/vhdl/stratixiv
stratixiv_hssi = $MODEL_TECH/../altera/vhdl/stratixiv_hssi
stratixiv_pcie_hip = $MODEL_TECH/../altera/vhdl/stratixiv_pcie_hip
cycloneiv = $MODEL_TECH/../altera/vhdl/cycloneiv
cycloneiv_hssi = $MODEL_TECH/../altera/vhdl/cycloneiv_hssi
cycloneiv_pcie_hip = $MODEL_TECH/../altera/vhdl/cycloneiv_pcie_hip
cycloneive = $MODEL_TECH/../altera/vhdl/cycloneive
stratixv = $MODEL_TECH/../altera/vhdl/stratixv
stratixv_hssi = $MODEL_TECH/../altera/vhdl/stratixv_hssi
stratixv_pcie_hip = $MODEL_TECH/../altera/vhdl/stratixv_pcie_hip
arriavgz = $MODEL_TECH/../altera/vhdl/arriavgz
arriavgz_hssi = $MODEL_TECH/../altera/vhdl/arriavgz_hssi
arriavgz_pcie_hip = $MODEL_TECH/../altera/vhdl/arriavgz_pcie_hip
arriav = $MODEL_TECH/../altera/vhdl/arriav
cyclonev = $MODEL_TECH/../altera/vhdl/cyclonev
twentynm = $MODEL_TECH/../altera/vhdl/twentynm
twentynm_hssi = $MODEL_TECH/../altera/vhdl/twentynm_hssi
twentynm_hip = $MODEL_TECH/../altera/vhdl/twentynm_hip
cyclone10lp = $MODEL_TECH/../altera/vhdl/cyclone10lp
; Verilog Section
altera_mf_ver = $MODEL_TECH/../altera/verilog/altera_mf
altera_ver = $MODEL_TECH/../altera/verilog/altera
altera_lnsim_ver = $MODEL_TECH/../altera/verilog/altera_lnsim
lpm_ver = $MODEL_TECH/../altera/verilog/220model
220model_ver = $MODEL_TECH/../altera/verilog/220model
maxii_ver = $MODEL_TECH/../altera/verilog/maxii
maxv_ver = $MODEL_TECH/../altera/verilog/maxv
fiftyfivenm_ver = $MODEL_TECH/../altera/verilog/fiftyfivenm
sgate_ver = $MODEL_TECH/../altera/verilog/sgate
arriaii_ver = $MODEL_TECH/../altera/verilog/arriaii
arriaii_hssi_ver = $MODEL_TECH/../altera/verilog/arriaii_hssi
arriaii_pcie_hip_ver = $MODEL_TECH/../altera/verilog/arriaii_pcie_hip
arriaiigz_ver = $MODEL_TECH/../altera/verilog/arriaiigz
arriaiigz_hssi_ver = $MODEL_TECH/../altera/verilog/arriaiigz_hssi
arriaiigz_pcie_hip_ver = $MODEL_TECH/../altera/verilog/arriaiigz_pcie_hip
stratixiv_ver = $MODEL_TECH/../altera/verilog/stratixiv
stratixiv_hssi_ver = $MODEL_TECH/../altera/verilog/stratixiv_hssi
stratixiv_pcie_hip_ver = $MODEL_TECH/../altera/verilog/stratixiv_pcie_hip
stratixv_ver = $MODEL_TECH/../altera/verilog/stratixv
stratixv_hssi_ver = $MODEL_TECH/../altera/verilog/stratixv_hssi
stratixv_pcie_hip_ver = $MODEL_TECH/../altera/verilog/stratixv_pcie_hip
arriavgz_ver = $MODEL_TECH/../altera/verilog/arriavgz
arriavgz_hssi_ver = $MODEL_TECH/../altera/verilog/arriavgz_hssi
arriavgz_pcie_hip_ver = $MODEL_TECH/../altera/verilog/arriavgz_pcie_hip
arriav_ver = $MODEL_TECH/../altera/verilog/arriav
arriav_hssi_ver = $MODEL_TECH/../altera/verilog/arriav_hssi
arriav_pcie_hip_ver = $MODEL_TECH/../altera/verilog/arriav_pcie_hip
cyclonev_ver = $MODEL_TECH/../altera/verilog/cyclonev
cyclonev_hssi_ver = $MODEL_TECH/../altera/verilog/cyclonev_hssi
cyclonev_pcie_hip_ver = $MODEL_TECH/../altera/verilog/cyclonev_pcie_hip
cycloneiv_ver = $MODEL_TECH/../altera/verilog/cycloneiv
cycloneiv_hssi_ver = $MODEL_TECH/../altera/verilog/cycloneiv_hssi
cycloneiv_pcie_hip_ver = $MODEL_TECH/../altera/verilog/cycloneiv_pcie_hip
cycloneive_ver = $MODEL_TECH/../altera/verilog/cycloneive
twentynm_ver = $MODEL_TECH/../altera/verilog/twentynm
twentynm_hssi_ver = $MODEL_TECH/../altera/verilog/twentynm_hssi
twentynm_hip_ver = $MODEL_TECH/../altera/verilog/twentynm_hip
cyclone10lp_ver = $MODEL_TECH/../altera/verilog/cyclone10lp
- Ken_I_Intel
Thanks for the info. I use standalone modelsim, but I just compile the quartus/eda/sim_lib/ sources directly from modelsim.
I suspect your right that the ini file will allow this because I have a testbench from somebody else and it allows starting vsim without having to type -L option and its in the [Library] section which mentor docs says will allow not having to type this in for commmon libraries, but when I cant seem to duplicate this in my own project.
I tried adding the altera_mf_ver library to modelsim.ini also the project.mpf file but I still have to type -L altera_mf_ver. Is there a way to tell what libraries are default loaded and runtime? This would help debug if its a modelsim.ini sytax read error or something else.
