laurent53240's avatar
laurent53240
5 years ago
modelsim starter edition licence linux
Hi
I use the quartus lite software on linux Ubuntu.
When I start simulation with modelsim starter edition an error occure:
error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
I try the re-install the Modelsim software, always this error. For me no licence file is not necessary.
in the EDA tools option for the modelsim software i have:
/home/laurent/intelFPGA_lite/20.1/modelsim_ase/linuxaloem
Some one has a solution ?
thank you
  • AR_A_Intel's avatar
    AR_A_Intel
    Hello
    Welcome to Intel forum. But before setting up Modelsim, would you kindly help check, whether your machine is supported or not (OS) by referring to link below:
    https://www.altera.com/support/support-resources/download/os-support.html
    For ModelSim software, you must set an environment variable the location of license. you need to specify location of the license file using the LM_LICENSE_FILE system variable (click/checkout the Use LM_LICENSE_FILE variable). You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provide. c:\intel\license.dat or something similar.
    Please stop and restart PC after assigning.
    You can refer to link on how to set environment variable.
    https://software.intel.com/en-us/articles/how-to-set-intel-license-file-environment-variable
    You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgGE
    Let me know if this information is helpful.
    AR_A_Intel
    Hi
    Based on my understanding, Ubuntu 20.04 version is not an officially support OS for ModelSim starter edition. An unsupported platform means that some things may work, but others not, and we won't put any resources into debugging or diagnosing. We recommended to use the right OS for ModelSim.
    • axolotl's avatar
      axolotl
      Doesn't work in supported linux either.
    AR_A_Intel
    Sounds good, thanks for sharing and hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
