modelsim starter edition licence linux
Hello
Welcome to Intel forum. But before setting up Modelsim, would you kindly help check, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
For ModelSim software, you must set an environment variable the location of license. you need to specify location of the license file using the LM_LICENSE_FILE system variable (click/checkout the Use LM_LICENSE_FILE variable). You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provide. c:\intel\license.dat or something similar.
Please stop and restart PC after assigning.
You can refer to link on how to set environment variable.
https://software.intel.com/en-us/articles/how-to-set-intel-license-file-environment-variable
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgGE
Let me know if this information is helpful.
- laurent532405 years ago
Hi
I use the Modelsim starter edition on Ubuntu 20.04, no licence is required. for me it is a path problem, but I don't know where
regards
Hi
The problem is solves by installing the 32 bits library and with some modifications of modelsim install.
the solution is explain in:
https://vhdlwhiz.com/modelsim-quartus-prime-lite-ubuntu-20-04/
Modelsim run correctly
Thank you
