Modelsim simulation error / couldn't open "transcript": permission denied
Hi Joon Hyeok,
Actually, the error "couldn't open "transcript": permission denied" can be ignored. The transcript is newly generated each time you run your simulation.
The problem you face may be due to a programming error in your testbench file. Can you attach your files here so I can better understand your problem? If your files are confidential, you can attach them in an email; I have just sent you an email regarding this issue.
Can you also let me know what version of ModelSim you are using?
Nurina
- Libejoon5 years ago
Thank you for your answer.
I asked about this problem to my professor
and I got the answer that this problem form my Window OS damaged.
and Pr told me that to solve the problem, format your hardware and reinstall Modelsim or
use virtual window.
So I choose Virtual window.
and the testbench file is made by my professor so it is clear entire.
No problem in testbench file.
