12 years ago[ModelSim] Passing real values to submodule
I am having a strange problem when I try to simulate my design. I would like to use real values for stimulus, since my design should work with double precision floats. But when I pass values from top module to submodule, they are not recognized correctly.
When I try to simulate the folowing code using ModelSim Altera Starter Edition 10.1d:
// top module
module realTest;
real a = 1.2345;
wire out_wire;
// stimulus
always# 10 begin
a <= a + 1.0;
# 5
$display("top module: 0x%x %f", out_wire, a);
end
// submodule instantiation
submodule submodule_inst (
.data (a),
.out (out_wire)
endmodule
// submodule
module submodule(
input data,
output out
// temporary value
real tmp;
always @ * begin
tmp <= data; // I THINK THE PROBLEM HAPPENS HERE
$display("inside submodule: 0x%x %f", data, tmp);
end
assign out = data;
endmodule
I get folowing result: # inside submodule: 0x3ff3c083126e978d 0.000000# inside submodule: 0x3ff3c083126e978d 4608238512912635900.000000# inside submodule: 0x4001e04189374bc6 4608238512912635900.000000# inside submodule: 0x4001e04189374bc6 4612214065483697200.000000# top module: 0x4001e04189374bc6 2.234500# inside submodule: 0x4009e04189374bc6 4612214065483697200.000000# inside submodule: 0x4009e04189374bc6 4614465865297382400.000000# top module: 0x4009e04189374bc6 3.234500# inside submodule: 0x4010f020c49ba5e3 4614465865297382400.000000# inside submodule: 0x4010f020c49ba5e3 4616453641582912500.000000# top module: 0x4010f020c49ba5e3 4.234500
We can see that hexadecimal values are always the same, problem happens in line where hex is converted to real. Does anybody have any idea what is wrong? Best regards, Jan
