15 years agoModelsim nativelink not working
I just upgraded to 10.1. The nativelink to Modelsim-Altera has stopped working. I looked at the xxxx_nativelink_simulation.rpt file and the messages don't give me much to go on: "Error: Can't l...
10 years ago --- Quote Start --- you should make sure the path in Tools > Options > EDA Tool Options is set to something like c:\altera\10.1\modelsim_ase\win32aloem can you manually launch ModelSim-ASE? --- Quote End --- Hi thepancake, I'm facing the same problem here. I have set the path correctly and yes i can launch the modelsim manually from the same path i set in the EDA tool options path. However, i still get the same error as mentioned in the first post when i try to run both RTL Simulation and Gate Level Simulation. Can you help tell me if i miss anything out? Thanks.
