11 years agoModelSim licensing problems after installing Opal Kelly license
I have a problem with my Quartus II installation, specifically that the ModelSim Altera starter edtion will not start, complaining about "Unable to checkout a license". The thing is, I am using...
11 years agoI have tried running it both from within Quartus II and outside of, both have the same behavior.
Actually, I did not try it before I installed the Opal Kelly license, I just assumed it was the license that I set up that broke it :) The path is set to C:\altera\14.1\modelsim_ase\win32aloem The splash says ModelSim Altera 10.3c On Alteras webpage "ModelSim Altera" and "ModelSim Altera Starter Edition" is the same download though, which I interpret as it will run as the starter edition in case you do not have a license. I have no other Quartus II install on my computer, but perhaps I should try to install an older version of just ModelSim...
