9 years agoModelsim is exiting with code 211.
Hi, every time I try to run a simulation with Modelsim I get: Modelsim is exiting with code 211. Then Modelsim closes. Transcript says: # vsim -gui work.test_counter # Start t...
9 years agoI highly doubt the code is causing this problem.
For future, I highly suggest you use Verilog 2001 styles, where you can specify input/output and type on the actual ports:
module counter (
output count,
input clk, reset
function increment ( val);
It is much more readable than verilog '95. I can only assume the crash is some setup issue. What OS are you using? How are you running the sim?
