9 years agoModelsim is exiting with code 211.
Hi, every time I try to run a simulation with Modelsim I get: Modelsim is exiting with code 211. Then Modelsim closes. Transcript says: # vsim -gui work.test_counter # Start t...
9 years agoSIGSEGV is a segmentation fault, - something is causing modelsim to crash.
You may have to raise a ticket with mentor to find the problem. Could you post the code for counter and test_counter?
