8 years agoModelSim Intel FPGA Starter edition 10.5b fails to simulate due to mem alloc fail
Just fired up ModelSim FPGA Starter edition 10.5b and tried to simulate the simplest of models to get a feel for the tool. The testbench contains a file reader pushing test vectors into a DUT stub. G...
8 years agoLIBRARY IEEE,STD;
USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_TEXTIO.ALL; USE STD.TEXTIO.ALL; ENTITY test_vector_reader IS GENERIC (NBITS : integer); PORT ( op1 : out std_logic_vector(NBITS-1 downto 0); op2 : out std_logic_vector(NBITS-1 downto 0); ref : in std_logic_vector(NBITS-1 downto 0)); END test_vector_reader; ARCHITECTURE behavior OF test_vector_reader IS BEGIN file_io: PROCESS IS FILE in_file : TEXT OPEN READ_MODE IS "addition_posit_5_0.vnv"; FILE out_file : TEXT OPEN WRITE_MODE IS "vnv_results"; VARIABLE out_line : LINE; VARIABLE in_line : LINE; VARIABLE nbits : INTEGER; VARIABLE es : INTEGER; VARIABLE testCase : INTEGER; VARIABLE a,b,c : STD_LOGIC_VECTOR(NBITS-1 downto 0); VARIABLE result : STD_LOGIC_VECTOR(NBITS-1 downto 0); BEGIN -- read and report the posit configuration READLINE(in_file, in_line); READ(in_line, nbits); READ(in_line, es); -- construct an output message to the console WRITE(out_line, string'("posit<")); WRITE(out_line, nbits); WRITE(out_line, string'(",")); WRITE(out_line, es); WRITE(out_line, string'(">")); WRITELINE(OUTPUT, out_line); -- read the test vector elements WHILE NOT ENDFILE(in_file) LOOP READLINE(in_file, in_line); READ(in_line, testCase); READ(in_line, a); READ(in_line, b); READ(in_line, c); -- construct an output message WRITE(out_line, a); WRITE(out_line, string'(" + ")); WRITE(out_line, b); WRITE(out_line, string'(" = ")); WRITE(out_line, c); WRITELINE(OUTPUT, out_line); -- schedule signal transactions op1 <= a; op2 <= b; WAIT; WRITE(out_line, result); WRITELINE(out_file, out_line); END LOOP; ASSERT FALSE REPORT "Simulation done" SEVERITY NOTE; WAIT; --allows the simulation to halt! END PROCESS file_io; END ARCHITECTURE behavior;
