Modelsim Intel FPGA Edition 2020.3 Pro and 2020.1 Standard license problem
Hi
Upon checking, as per logs, it is throwing below error message i.e. license codes are generated for one host ID and license file being used in another HOSTID.
FlexNet Error
Error Number: -8
Error Message: Invalid (inconsistent) license key.
Server: C:\FLEXLM\license.dat
Feature: alteramtivsim
FlexNet Error
Error Number: -8
Could you confirm whether customers run the tool on same HOST or different HOST when they upgrade to 20.4?
If it is on different HOST when running 20.4, then could you try 20.4 version on same HOST where 2019.4 is working fine as it looks licenses are generated on 2019.4 HOST ID.
Lastly, is it possible to run the 2019.4 tool with same MGLS_DEBUG_LOG_DIR settings and provide the logs please?
Thank you very much.
Hi.
Both versions of the simulator - 19.4 and 20.4 - run on the same HOST computer.
Attached both log files.
Elit
- AR_A_Intel5 years ago
Hi
Thank you for sending the MGLS_DEBUG_LOG_DIR logs of 2019.4 version.Can you please download latest licensing software from below link and install it.
https://support.sw.siemens.com/en-US/product/905395197/downloads
Default it installs into c:\MentorGraphics\Licensing folder.
In Command Prompt go to c:\mentorgraphics\licensing folder, and then run the command “mgls_ok.exe alteramtivsim “ command to check whether it is checking out licenses or not.
Attach is the screen shot for command execution.
Could you help to test “mgls_ok.exe alteramtivsim”?
- Elit5 years ago
Hi.
Attached screenshot (pdf) of license check and license file.
Elit
Hi
Our RDs provide the following feedbacks:
Could you help to send the MAC Address of the system to us?
One way is to have the MAC Address reported in lmtools->System Settings window. Refer to attachment.
We are investigating the root cause of this issue.
