Modelsim Intel FPGA Edition 2020.3 Pro and 2020.1 Standard license problem
Hi
Thanks for update. I’m checking with engineering team on this. I’ll get back with an update.
Hi
Upon checking. Could you help to follow the steps below to test the environment, and provide further information?
1) Download Attached license.dat file into C:\FLEXLM folder (IF C:\FLEXLM folder doesn’t exist, then please create the folder)
2) Create DEBUG_LOG folder under c:\FLEXLM folder
3) Create MGLS_DEBUG_LOG_DIR Environment variable and set the value to c:\FLEXLM\DEBUG_LOG
4) Open and run the tool
5) When you get any license error then exit the tool.
6) After exiting, it dumps logs under c:\FLEXLM\DEBUG_LOG folder. Please send us all logs.
Thank you very much.
- Elit5 years ago
Hi.
Attached debug log file.
Elit
