Modelsim Intel FPGA Edition 2020.3 Pro and 2020.1 Standard license problem
Hi
Thanks for update. I’m checking with engineering team on this. I’ll get back with an update.
- AR_A_Intel5 years ago
Hi
Upon checking. Could you help to follow the steps below to test the environment, and provide further information?
1) Download Attached license.dat file into C:\FLEXLM folder (IF C:\FLEXLM folder doesn’t exist, then please create the folder)
2) Create DEBUG_LOG folder under c:\FLEXLM folder
3) Create MGLS_DEBUG_LOG_DIR Environment variable and set the value to c:\FLEXLM\DEBUG_LOG
4) Open and run the tool
5) When you get any license error then exit the tool.
6) After exiting, it dumps logs under c:\FLEXLM\DEBUG_LOG folder. Please send us all logs.
Thank you very much.
- Elit5 years ago
Hi.
Attached debug log file.
Elit
