osmanyagci
4 years agoModelSim*-Intel® FPGA Edition Software - Simulation Error
When I try to simulate my design in modelsim, it warns me that a module named as fourteen_iossm_mchip_encrypted does not exits. I tried to find that module under the Quartus 20.4 installition ...
ShengN_altera
4 years agoHi
Could you provide the design file for further debugging?
Sheng
- osmanyagci4 years ago
The original project file is at the link given below under Windows BSP. I have modified some parts of it so that I can make tests on that. The project is generated using platform designer, so to make a test on modelsim I have generated vhdl files for the ips using platform designer.
I have a Intel Quartus Pro licence. However, I am using modelsim altera starter edition. Is it possible that this causes the issue? Do I have to use modelsim altera edition instead of altera starter edition? When I clicked on the modelsim altera edition it says the following error?
