11 years ago[ModelSim] How to set support to VHDL-2011 ?
Hi All, How can I set support to VHDL-2011 in ModelSim? Actually I've put the VHDL93 = 2008 line in the modelsim.ini, but it seems it does not catch it. At least, then I try to use an outp...
11 years ago --- Quote Start --- how do you compile? using the vcom -2008? --- Quote End --- Actually I compile using ModelSim icons, not a script or console commands. So, I'd like to define VHDL-2008 as a global option in the modelsim.ini . How can I do so?
