11 years ago[ModelSim] How to see local variables in VHDL procedures in waveforms?
Hi All, How can I see the variables, which were locally defined in the VHDL procedures, in the waveform? Somehow I cannot see nor the procedures themselves nor their variables. Should I a...
11 years ago --- Quote Start --- you can label your process and then add it to the waveform manually. To do this: 1- Generate a simple waveform without variables 2- save it with .do format. For example my_wave_1.do 3- Manually open the my_wave_1.do file in a text editor and add your variable to a line. You can copy/paste previous lines for simplicity. Then replace the signal name with your variable name: dut/my_process/v_variable 4- Save your edited .do file 5- now run in the console: do my_wave_1.do 6- Run Simulation --- Quote End --- The OP asked for procedures not processes.
