11 years ago[ModelSim] How to see local variables in VHDL procedures in waveforms?
Hi All, How can I see the variables, which were locally defined in the VHDL procedures, in the waveform? Somehow I cannot see nor the procedures themselves nor their variables. Should I a...
11 years agoUsing textio, there is a default file called OUTPUT that allows you to write to the simulator console.
you can do it one of two ways. 1. Like normal textio, write to a line then write the line to the console:
variable l : line;
write(l, string'("This is some debug text"));
writeline(OUTPUT, l);
or write drictly to output. Heres a nice little wrapper procedure for you.
procedure echo (arg : in string := "") is
begin
std.textio.write(std.textio.output, arg);
end procedure echo;
--echos to console with a newline at the end
procedure echol(arg : in string := "") is
begin
std.textio.write(std.textio.output, arg & LF);
end procedure echol;
