13 years agoModelsim: How to change default time unit?
I'd like to change the timeunit for Modelsim. By default Modelsim uses ps, but I'd like to change to ns. Currently if I issue the command run 1000 in the wave window, the time advances 1000ps. I'd like that to run 1000ns.
Where can I define the default time unit to ns? I have tried changing both the Resolution and UserTimeUnit variables in the modelsim.ini file and neither of those did the trick. Is that setting set somewhere else? Thanks, -phil
