KURK123
8 years agoModelsim error
I have a code which compiles correctly but when I simulate it using ModelSim, it gives me this warning: Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es)....
KURK123
8 years agoTricky,
Thank you for your suggestions.
I have implemented your second suggestion of suppressing warnings from IEEE packages in the simulation settings.
Let me try tracing back the output signal and see which signals are uninitialized.
I will post my findings here.
This might lead me somewhere.
Thank you once again.
