KURK123
8 years agoModelsim error
I have a code which compiles correctly but when I simulate it using ModelSim, it gives me this warning: Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es)....
KURK123
8 years agoHi Vikas,
Thanks for your reply.Yes I have compiled the design successfully and then initialized the inputs and outputs. in the test bench.
I think I should be initializing the output as well ( which I have not done). Will this cause the output to be in uninitialized state all the time
throughout the execution of the code?
KURK
