15 years ago
modelsim error
Hi, I'm new in hdl programming, I just installed Modelsim Altera Starter Edition 6.6d, and I can't create any library.
When I started modelsim it created file with name transcript. It has following content:
# Reading C:/altera/11.0/modelsim_ase/tcl/vsim/pref.tcl # error: Load_NoDesignLayout can't read "map( )": no such element in array# can't read "map( )": no such element in array# while executing# "subst -nocommands $string"# (procedure "encode" line 11)# invoked from within# "encode $ukey"# (procedure "getMTIProperty" line 11)# invoked from within# "getMTIProperty $geomKey main_size "" "# (procedure "LoadLayout" line 35)# invoked from within# "LoadLayout NoDesign quitsim"# ("eval" body line 1)# invoked from within# "eval "LoadLayout $new_layout_name quitsim""# (procedure "Layout::Load_NoDesignLayout" line 3)# invoked from within# "Layout::Load_NoDesignLayout"
When I tried to shut modelsim window, I had an error in tcl script: can't read "map(P)": no such element in array. And window didn't shut. After killing vish process I had tcl_stacktrace.txt with:
Thu Sep 15 11:19:03 ?????????? ????? (????) 2011
Trace back: can't read "map(?)": no such element in array
while executing
"quit"
(command for "WM_DELETE_WINDOW" window manager protocol)
<2: ::tkerror {can't read "map(?)": no such element in array}
<1: ::bgerror {can't read "map(?)": no such element in array}
Thu Sep 15 11:20:21 ?????????? ????? (????) 2011
while executing
"quit"
I tried to ask google, but it had nothing interesting. May be somebody had this problem.
Windows XP SP2 (32-bit); Modelsim Altera Starter Edition 6.6d
1 Reply
    Hi biv,
    Where do you launch ModelSim? I had similar error when I launched ModelSim from the shortcut on my Windows Desktop, but ModelSim can successfully be launched when I launch it from Start Menu.
