11 years ago
Modelsim Error: (vcom-11) Could not find altera.maxplus2
Hello all,
I am completely new to vhdl, altera and modelsim so please bear with me if the question is too simple. I have tried to scout the web for any leads - but so far without any real progress.
I have created a simple structural design based on 74xxx components from the altera maxplus2 library (altera\13.0\quartus\libraries\vhdl\altera). I know this can be done as behavioral - but I am transferring an old TTL design that I want to verify.
I have included in my vhdl file:
LIBRARY altera;
USE altera.maxplus2.ALL;
Following setp by step the "getting started wtih quartus ii simulation using the modelsim-altera software" guide to open up modelsim with nativelink I get the following error message in the transcript window:
# ** Error: (vcom-11) Could not find altera.maxplus2.
And from this point I cannot progress. I have tried to compile the maxplus2 library with the modelsim compile functionality - but in all honesty I am not really sure what I am doing. I get a maxplus2 folder in RTL-WORK directory - but it doesnt help at all as I get the same error when I re-execute the "do"-command line.
Any pointers as to where I can look for further reading on this topic or any advice to resolve this is highly appreciated.
br /mattias
fyi: I work in msft windows environment.
1 Reply
    All,
    I found a potential solution over at xlinx's forum: http://www.xilinx.com/itp/xilinx10/isehelp/pp_p_process_compile_hdl_simulation_libraries.htm
    From that discussion I used the following command:
    vcom -93 -explicit -reportprogress 300 -work altera {C:\altera\13.0\work\maxplus2.vhd}
    It appears that quartus' maxplus2 library gets compiled into the existing modelsim altera library.
    Following this i could re-compile my "design" without any issues and get into simulation window.
    Not sure whether this is the "appropriate" and long term solution - and not sure if it works as i have not completed my simulation yet - i have quite a few "vsim-3473 component not bound" errors to resolve first :-)
    Please let me know if you have any other thoughts.
    br /mattias
