Modelsim ASE starter not directly support UVM
- 5 years ago
Unfortunately ModelSim does not have pre-compiled UVM features. You are probably thinking of Questa Sim.
You need to download UVM source files, you can do that here: https://www.accellera.org/downloads/standards/uvm
And you'll need to compile the uvm_pkg as well.
vlog -work work -sv -stats=none C:/work/ST/simulation/tb_captur_1.sv <uvm_pkg path>/uvm_pkg.sv +incdir+<UVM source path>/src
Nurina
Hi Nurina
Good news! I found Starter Edition 20.1 can run with original UVM src (installed with modelsim). This morning I ran a wrong shortcut after a modelsim crash, I'm sorry.
Now with version 20.1, both original installed UVM src or separated downloaded source code (you suggested), can run successfully.
I will use the earlier 20.1 for current job, thanks.
I think I already have "accept as solution" for the original question, so it will be fine?
Glad your problem is solved! No problem with "accept as solution" for original question, you can also leave Kudos if you like my comment.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
