Modelsim ASE starter not directly support UVM
- 5 years ago
Unfortunately ModelSim does not have pre-compiled UVM features. You are probably thinking of Questa Sim.
You need to download UVM source files, you can do that here: https://www.accellera.org/downloads/standards/uvm
And you'll need to compile the uvm_pkg as well.
vlog -work work -sv -stats=none C:/work/ST/simulation/tb_captur_1.sv <uvm_pkg path>/uvm_pkg.sv +incdir+<UVM source path>/src
Nurina
Maybe you downloaded the wrong UVM source file? It's odd that you're seeing this error because our internal team has fixed this error in Quartus v17.0.
OK I shall close this thread. I’m glad that your original question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
Hi Nurina
I use the UVM src together with the modelsim installation. I think it should has best compatibility.
You mentioned the error has been fixed in Quartus. My installation of elder version 20.1, only include modelsim starter edition, no Quatus 20.1 installed. Would this installation type runs well?
