Modelsim ASE starter not directly support UVM
- 5 years ago
Unfortunately ModelSim does not have pre-compiled UVM features. You are probably thinking of Questa Sim.
You need to download UVM source files, you can do that here: https://www.accellera.org/downloads/standards/uvm
And you'll need to compile the uvm_pkg as well.
vlog -work work -sv -stats=none C:/work/ST/simulation/tb_captur_1.sv <uvm_pkg path>/uvm_pkg.sv +incdir+<UVM source path>/src
Nurina
Do you have any updates?
Nurina
- xuyang5 years ago
Hi Nurina
Sorry for late response, I just back from vacation.
I tried v20.1 in another server, but the result is the same:
# Top level modules:
# tb_capture_1
# vsim -c tb_capture_1 -voptargs=""+acc=r""
# Start time: 10:47:37 on Jul 13,2021
# ** Fatal: (vsim-7019) Can't locate a C/C++ compiler for 'DPI Export Compilation'.
# FATAL ERROR while loading design
# Error loading design
# Error: Error loading designI already set the environment variable in that server, and use same command parameters.
Since the problem is already different from original question, I think you might close this question, and I may do some experiment in different tools. Thanks for so much helps!
