xuyang
5 years agoModelsim ASE starter not directly support UVM
Hi Guys, I installed modelsim ASE starter edition 2021.02.
From common knowledge, I thought this tool has pre-compiled UVM features. But after I installed, I found `include "uvm_macros.svh" cannot ...
- 5 years ago
Unfortunately ModelSim does not have pre-compiled UVM features. You are probably thinking of Questa Sim.
You need to download UVM source files, you can do that here: https://www.accellera.org/downloads/standards/uvm
And you'll need to compile the uvm_pkg as well.
vlog -work work -sv -stats=none C:/work/ST/simulation/tb_captur_1.sv <uvm_pkg path>/uvm_pkg.sv +incdir+<UVM source path>/src
Nurina
Nurina
5 years agoHi,
I was able to compile it on ModelSim Intel FPGA Starter Edition Version 2020.1, can you migrate to this version instead? You can download the individual ModelSim file here: https://fpgasoftware.intel.com/20.1/?edition=standard&platform=windows
Nurina
xuyang
5 years agoHi Nurina
I will try to downgrade my version, then tell you the result later. Thanks.
