xuyang
5 years agoModelsim ASE starter not directly support UVM
Hi Guys, I installed modelsim ASE starter edition 2021.02.
From common knowledge, I thought this tool has pre-compiled UVM features. But after I installed, I found `include "uvm_macros.svh" cannot ...
- 5 years ago
Unfortunately ModelSim does not have pre-compiled UVM features. You are probably thinking of Questa Sim.
You need to download UVM source files, you can do that here: https://www.accellera.org/downloads/standards/uvm
And you'll need to compile the uvm_pkg as well.
vlog -work work -sv -stats=none C:/work/ST/simulation/tb_captur_1.sv <uvm_pkg path>/uvm_pkg.sv +incdir+<UVM source path>/src
Nurina
xuyang
5 years agoHi Nurina
I'm not simulate it in quartus environment. I directly build a modelsim project, and the rtl is quite simple. You can check this in attach file.
