12 years ago
Modelsim and CycloneV PLL : flat output
Hello everyone,
I am trying to simulate a QSys design with Nios and custom IPs, one of them including a reconfigurable pll.
I am able to compile my design, simulate it, but when simulating, clock outputs from the pll stay at a value of '0' and it doesn't lock.
What makes it tricky is that I can simulate the IP which contains the PLL with a testbench and everything works fine. but when this IP is placed in a wider qsys design it doesn't work.
I watched pll inputs ant outputs, nothing seems suspect except its flat outputs :
pll startup :
https://www.alteraforum.com/forum/attachment.php?attachmentid=8865
as you can see, output clocks stay flat, but reconfig_from_pll has a legit value.
the libraries I use in my design :
    vlog     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_primitives.v"                       -work altera_ver
    vlog     "$QUARTUS_INSTALL_DIR/eda/sim_lib/220model.v"                                -work lpm_ver
    vlog     "$QUARTUS_INSTALL_DIR/eda/sim_lib/sgate.v"                                   -work sgate_ver
    vlog     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_mf.v"                               -work altera_mf_ver
    vlog -sv "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/altera_lnsim_for_vhdl.sv"           -work altera_lnsim_ver
    vlog     "$QUARTUS_INSTALL_DIR/eda/sim_lib/cyclonev_atoms.v"                          -work cyclonev_ver
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_syn_attributes.vhd"                 -work altera
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_standard_functions.vhd"             -work altera
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/alt_dspbuilder_package.vhd"                -work altera
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_europa_support_lib.vhd"             -work altera
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_primitives_components.vhd"          -work altera
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_primitives.vhd"                     -work altera
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/220pack.vhd"                               -work lpm
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/220model.vhd"                              -work lpm
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/sgate_pack.vhd"                            -work sgate
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/sgate.vhd"                                 -work sgate
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_mf_components.vhd"                  -work altera_mf
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_mf.vhd"                             -work altera_mf
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_lnsim_components.vhd"               -work altera_lnsim
    vlog     "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/cyclonev_atoms_ncrypt.v"            -work cyclonev
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/cyclonev_atoms.vhd"                        -work cyclonev
    vcom     "$QUARTUS_INSTALL_DIR/eda/sim_lib/cyclonev_components.vhd"                   -work cyclonev
they are all given as -L arguments to the vsim command.
the pll simulation file I use :
  vcom     "D:/dev/TstPtfm/output_files/testbench/TstPtfm_tb/simulation/submodules/altera_pll_clock_gen.vho"              -work clock_generator
when vsim loads the component :
#  Loading clock_generator.clock_def_pkg(body)#  Loading clock_generator.f_clock_generator_ip(imp)#  Loading altera_lnsim.altera_lnsim_components#  Loading clock_generator.altera_pll_clock_gen(rtl)#  Loading sv_std.std#  Loading cyclonev_ver.cyclonev_lcell_comb#  Loading ieee.vital_timing(body)#  Loading ieee.vital_primitives(body)#  Loading cyclonev.cyclonev_atom_pack(body)#  Loading cyclonev.cyclonev_components#  Loading sgate.sgate_pack(body)#  Loading clock_generator.altera_pll_reconfig_clock_gen(rtl)
it seems that all necessary libraries are loaded.
I already RTFM and googled my problem. The only thread that could be related is :
http://www.alteraforum.com/forum/showthread.php?t=42356&referrerid=90168
I already had to deal with this "error in protected content" issue and used the solution given in the thread (include verilog lib).
My question is simple : do you have any idea of what is happening and how to solve it?
Thank you for reading all this and have a good day!
    I haven't run into this problem myself. But I think you need to ask yourself if it works fine for you in isolation, but fails when integrated into the larger system: what changed?
    From your description, it sounds like you might be using your own Modelsim scripts instead of the Qsys generated ones; your list of libraries doesn't match what I have in my projects which use the msim_setup.tcl from Qsys 13.1 Have you tried using the Qsys testbench scripts just to see it lock (or not)?
    Sooooo... I finally managed to make this pll work.
    I originally used a first pll to provide its clock input, starting up after a short while. I used its "locked" signal as a reset so that my problematic pll didn't try to sync without input (cf printscreen from the first post). I switched for an independent clock source, starting up without delay, and suddenly it works.
    So my conclusion is : never let a pll without input clock, even if it's in reset (at least in modelsim).
