12 years agoI haven't run into this problem myself. But I think you need to ask yourself if it works fine for you in isolation, but fails when integrated into the larger system: what changed?
From your description, it sounds like you might be using your own Modelsim scripts instead of the Qsys generated ones; your list of libraries doesn't match what I have in my projects which use the msim_setup.tcl from Qsys 13.1 Have you tried using the Qsys testbench scripts just to see it lock (or not)?
