16 years ago
Modelsim and altfp blocks
I'm attempting to simulate (functional level) a VHDL design using ModelSim that contains altfp_div and an altfp_conv blocks from the altera_mf library. These compile fine in Quartus, but when I try to compile the VHDL in Modelsim it gives me an error because the Modelsim altera_mf library does not contain any altfp blocks except altfp_mult.
Is there any way to add the missing altfp blocks to the Modelsim libary, or is this a limitation of the starter edition of ModelSim-Altera?
    i'm not seeing the same results as you. i'm using Quartus II 9.1sp2 and the accompanying ModelSim-AE version.
    i do confirm that altera_mf only contains an altfp_mult, but the altfp_div.vhd i created with the MegaWizard does compile fine in ModelSim.
    vcom -reportprogress 300 -work work /home/thepancake/testfp/testfp.vhd
    #  Model Technology ModelSim ALTERA vcom 6.5b Compiler 2009.10 Oct  1 2009
    #  -- Loading package standard
    #  -- Loading package std_logic_1164
    #  -- Compiling entity testfp_altfp_div_pst_tre
    #  -- Compiling architecture rtl of testfp_altfp_div_pst_tre
    #  -- Compiling entity testfp_altfp_div_8ah
    #  -- Compiling architecture rtl of testfp_altfp_div_8ah
    I'm instantiating the altfp_div block in VHDL directly without using the megawizard:
    LIBRARY altera_mf;
    USE altera_mf.altera_mf_components.all;
    div0: altfp_div
        GENERIC MAP
    	WIDTH_EXP => FP_WIDTH_EXP,
    	WIDTH_MAN => FP_WIDTH_MAN,
    	ROUNDING => "TO_NEAREST",
    	REDUCED_FUNCTIONALITY => "YES",
    	PIPELINE => FP_DIV_PIPELINE,
    	EXCEPTION_HANDLING => "NO",
    	OPTIMIZE => FP_DIV_OPTIMIZATION
        PORT MAP
            clock => clk,
            clk_en => calc_en,
            aclr => clr,
            dataa => inputs.if,
            datab => inputs.rf,
            result => rfDivRes
    This works fine in Quartus II 9.1. The component declaration for altfp_div is in the altera_mf_components package file (comes with Quartus). I generally use this style of coding so that I can easily change any of the parameters for the div block from parameters from the parent.
    I see your problem - I only have altfp_mult in the altera_mf library too. Raise a case via mysupport.
    I created a mysupport for this and got the following response:
    There is no behavioral model for altfp_div in the simulation library, thus you will need to include the MegaWizard instantiation in your source RTL for RTL (functional) simulation. Otherwise, you can try to run a Gate Level simulation to verify your design.
