11 years agoModelSim-Altera License ERROR
I've installed Quartus II 15.0, and ModelSim on my Ubuntu Linux 14.04 LTS and I keep get the same error messgae when I want to simulate my design with RTL simulation. The message says that in the file:://path/to/project-folder/project-name_nativelink_simulation.rpt I can read more details about the error. and in this file it's written:
"Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file." I really need to simulate for my project and I want to learn use ModelSim but I can't focus on the design due to these errors... The full text of this .rpt file is attached here:Info: Start Nativelink Simulation processInfo: NativeLink has detected a mixed Verilog and VHDL design -- verilog simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cycloneive
Quartus root : /path/to/Quartus/15.0/instalation/quartus/linux64/
Quartus sim root : /path/to/Quartus/15.0/instalation/quartus/eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : verilog
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation/modelsim
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script /path/to/Quartus/15.0/instalation/quartus/common/tcl/internal/nativelink/modelsim.tcl
Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: issued_nl_message
Nativelink TCL script failed with errorInfo: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
while executing
"error "$emsg" "" "issued_nl_message""
invoked from within
"if {
set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..."
(procedure "launch_sim" line 89)
invoked from within
"launch_sim launch_args_hash"
("eval" body line 1)
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $savedInfo $savedCode
} else {
invoked from within
"if {
set status 1
if {
set sav..."
(procedure "run_sim" line 78)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
"if {
error "$result" $savedInfo $savedCode
} else {
er..."
(procedure "run_eda_simulation_tool" line 336)
invoked from within
"run_eda_simulation_tool eda_opts_hash" 4 Replies
during the installation process, I've always chosed the options which are free no charge and require no license. I've implemented the whole installation process again today and I received the same error.
Can you try with Modelsim Altera starter edition which is free? The Modelsim Altera version should require license. - Altera_Forum
Hi doron.behar,
Do you have Windows to try out to see if it is due to OS issue? - Altera_Forum
No but I've entered the following command to the terminal and it solved the problem:
sudo apt-get install libxft2 libxft2:i386 lib32ncurses5 Thanks to your help bfkstimchan and tiny007 but I've received help in this website as well: http://stackoverflow.com/questions/31908525/modelsim-altera-error (http://stackoverflow.com/questions/31908525/modelsim-altera-error/31947317#31947317)
