14 years agoOkay, maybe you're right, if I'm manually adding signals to the wave window and just playing around, it only takes 5 seconds to drag drop and export the data. The time it takes me to learn enough Tcl to put together a kludge to parse the file would probably surpass the time I spend manually exporting the data. Learning to push the data out via SystemVerilog would pay dividends in the long run.
Most of our design guys use Eldo, but maybe there is an available Modelsim-SE seat floating around somewhere that I could play with, good idea.
